Nw Macpro needs OpenGL test?
Posted by Erik Naso on August 19, 2009 at 3:12 amI have a new Macpro with FCS 2. I installed BCC 5 and can’t get openGL effects to work. I want to use lens flare, I get “Filter Disabled Please click the test openGL HW button in the options for more information. I cant find “Option”. Its not in the interface. Please help.
Erik Naso replied 17 years, 1 month ago 4 Members · 6 Replies -
Matt Mullen
August 19, 2009 at 5:14 pmErik,
The button you are talking about should be in the filter controls.
The first things you need to look at is the graphics card model, OS version, and processor in the machine.
Post this information and I may be able to tell you why you are seeing this.
Matt -
Peter Mcauley
August 19, 2009 at 5:16 pmHi Erik,
Sorry to say that’s a mistake in the doc as there is no hardware test button in the FxPlug filters.
To solve the problem, you should:
• make sure you have the last version of BCC 5 or better yet use the BCC 6 version
• if you have After Effects, run the BCC OGL filter in AE and perform the hardware test by clicking the options button at the top of the filter, which pops up the OGL test window. If you click the Test Open GL Hardware button and it passes then it will enable use of the OGL filters in FCP. If it fails, you can manually enable the filter by clicking the enabled button in the pop-up
• check your system against the system requirements page on the borisfx.com website – if your video card is listed then the filters should work.
Once again, I suggest upgrading to the latest version for the best OGL performance but at a minimum, the filters should work on a MacPro system.
I hope this helps,
Peter.
Erik Naso
August 20, 2009 at 3:54 amAll fixed. Thanks for the help. I updated to 5.0.7 and that fixed the problem.
https://www.mediaartproductions.com
Rick Sebeck
August 26, 2009 at 3:57 pmWhere did you get the 5.0.7? Boris’ site only goes up to 5.0.1.50.
When I click on the Options button, AE freezes. This happens on two of my machines.
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 6 GBATI Radeon HD 2600 XT:
Chipset Model: ATI Radeon HD 2600
Type: Display
Bus: PCIe
Slot: Slot-1
PCIe Lane Width: x16
VRAM (Total): 256 MB
Vendor: ATI (0x1002)
Device ID: 0x9588
Revision ID: 0x0000
ROM Revision: 113-B1480A-252
EFI Driver Version: 01.00.252
Displays:
DELL 2005FPW:
Resolution: 1680 x 1050 @ 60 Hz
Depth: 32-Bit Color
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Rotation: Supported
DELL 2005FPW:
Depth: 32-Bit Color
Mirror: Off
Online: Yes
Rotation: SupportedEditor
Peter Mcauley
August 26, 2009 at 4:14 pmHi Rick,
I’m not actually sure where you can find that – I suggest you send an email off to support@borisfx.com and one of the tech support gurus will be happy to assist you with this.
Cheers,
Peter.
Erik Naso
August 26, 2009 at 5:24 pmhttps://www.borisfx.com/updates/#null
this is for bcc5 fxplug for final cut. It’s on the bottom of the page for macs.https://www.mediaartproductions.com
