Activity Forums Adobe After Effects NVIDIA GT 540M & Adobe After effects issue
  • NVIDIA GT 540M & Adobe After effects issue
    Posted by Rohan Gopalan on January 22, 2012 at 7:37 pm
    I have recently purchased a Toshiba Qosmio F750 1005x laptop with i7,8gb ram & Nvidia GT 540M. I need to work on After Effects alot & have discovered that my graphic card does not support Adobe Aftereffects. I have been trying to look for solutions online but really cannot find any. Somebody please help me out.
    Tudor “ted” jelescu replied 14 years, 8 months ago 2 Members · 3 Replies
  • Tudor “ted” jelescu
    January 22, 2012 at 7:47 pm
    When you say “have discovered that my graphic card does not support Adobe Aftereffects” you are probably referring to OpenGL support for AE, in which case you should not worry a bit since even Adobe does not recommend using that for preview or render. AE will work just fine with that card. What I would look for is for more RAM – see if your machine supports more of it and then upgrade to the max since AE uses RAM.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Rohan Gopalan
    January 22, 2012 at 8:37 pm
    I have allowed 6.5gb of ram out of 8gb for after effects cs5, but the problem is as soon as i scrub on any parameter it crashes and it says my nvidia driver crashed and has is working again. but the software crashes. also i just read on the nvidia forum, about 7-8 differnt users with the same gt 540m had the same complain but there was no reply from nvidia… and pretty weirdly just now i was workin on after effects and it did not crash.. surprisingly after your reply…:).. hopefully it wont crash again.. n could u recommend me wat settings i should use in the memory n cache settings.. m using cs3.. thank you so much
    January 23, 2012 at 7:33 am
    Make sure you have the latest available updates for CS 3. I would recommend saving up and upgrading to CS 5.5 soon.
    Tudor “Ted” Jelescu
    Senior VFX Artist
