Activity Forums Adobe After Effects NVIDIA Eye Contact
  • NVIDIA Eye Contact
    Posted by William Allum on October 20, 2023 at 4:36 pm
    NVIDIA have come out with this amazing tool not so long ago that can change eye contact in video. The main use of this seems to be for live video, and to change someone looking away so that their eyes are always in contact with the camera.
    https://www.nvidia.com/en-gb/geforce/news/jan-2023-nvidia-broadcast-update/
    My question… is there something similar to this for After Effects, and instead of changing the eye contact to camera, I would like to change eye contact to the side or off camera. The reason for this, I have some video of an actor that makes eye contact with the camera several times, briefly, and I need to redirect this (and no, it is unfortunately not possible to re-film).
    As far as I can see, there is no option for this on the NVIDIA app, unless someone knows otherwise. Plus I mainly use after effects, so if there is an option within after effects, that would be best.
    Thank you in advance.
    Graham Quince replied 2 years, 10 months ago 3 Members · 2 Replies
  • Hector Vera
    October 23, 2023 at 11:39 pm
    Perhaps this can give you some ideas on eye contact effects you can use in After Effects: https://youtu.be/1zSmUlCp2is?si=DjNnYEd6ySLS5zNC
    This is for eye replacement but it may help get you closer to what you are looking for when it comes to editing eye contacts in Adobe After Effects. Hope it helps! 🙂
  • Graham Quince
    October 24, 2023 at 1:05 pm
    It might also be worth checking out the face tracking tools (they appear in the tracker when you draw a circular mask around the model’s head). These give you more position options – although it’s splitting hairs really as you still have a lot of manual work to do.
