Activity Forums DaVinci Resolve Nvidia 5xx series??
  • Nvidia 5xx series??
    Posted by Andrew Smith on January 27, 2012 at 10:25 pm
    Hello
    It was my understanding that in the 12-core macpro the highest I can go is the 470 but a friend just sent me this link:
    https://www.youtube.com/watch?v=xYa39Y5nR6A
    However macvidcards says “The 5xx series cards don’t have a working EFI…no boot screens…If you don’t need boot screens then you can do this GTX580 mod”.
    I am currently running the 120/285 combo with a decklink 3D and its hdmi plate taking up the other 2 PCI slots.
    I want to make sure I know what the best card to purchase is (without using a cubix) before buying on ebay – I am also willing to upgrade to Lion if need be. I would most likely just keep the gt120 as its working fine for now but If anyone has suggestions for something to swap out for while i am upgrading my 285 to a 470 or whatever then please advise!
    Thanks in advance for any advice or help.
    David Pirinelli replied 14 years, 7 months ago 4 Members · 3 Replies
  • Juan Morales
    January 28, 2012 at 12:36 am
    Question is: will Resolve work with this card as 2nd CUDA card? Would be nice running next to my GTX120…
  • Mikhail Puzyrev
    January 28, 2012 at 10:21 am
    every 5xx except 590 will work.
  • David Pirinelli
    January 28, 2012 at 11:44 am
    Since I have been unable to make the GF100 EFI work on these GF110 cards, they can currently only be run using Netkas’ ATY_Init. This means no boot screens and that the cards will require adding the device id to the GF100 kext and they will most likely run at 2.5GT/s .
    They won’t ever work in 10.6.8.
    They will likely require the device id added in with every OS update, unless Apple/Nvidia decides to start including them.
    IN my experience, they require adding their device id also to the AGPM kext. (with GF100 cards you can just throw it out).
    I will try again and may eventually figure them out but for 10% more speed, they are currently quite a bit more bother.
