Activity Forums Avid Media Composer Numerical Keypad Enter Key
  • Numerical Keypad Enter Key
    Posted by Alec Gitelman on April 16, 2014 at 3:47 pm
    Trying to find the answer to the following question.
    Working in a facility with several edit stations I find that on some of them I cannot use the numerical keypad enter key to speed up putting markers. What I mean is this: usually when you put down a marker a dialog box pops up. After typing in your notes you can click the OK button or (usually) you can just use the Enter key on the numerical pad on the right of the keyboard to OK it. On some stations it doesn’t work, instead it works as a regular Enter and adds lines in comments. All stations run AVID v6.0.1.
    Any ideas?
    Alec Gitelman replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
