Activity Forums Adobe After Effects numbers disappear
  • numbers disappear
    Posted by Tom Dempsey on July 22, 2007 at 5:39 pm
    i’ve run into this before and can’t figure out what i’ve done.
    i’m changing my position variables (coordinates) and all of a sudden
    all of my number information disappears. no variables for position, rotation, anchor point… nothing. i must be hitting some sort of
    option key or something. does anyone know why this is happening?
    i’ve already tried restarting the app and nothing changes.
    tom dempsey
    Joshua Sarlo replied 10 years, 11 months ago 3 Members · 2 Replies
  • Terry Coolidge
    July 23, 2007 at 6:14 pm
    Sounds like you are invoking the “Collapse the Layer Switches pane” command. I’m not sure what the keyboard shortcut is for that, but there is a GUI toggle switch in the lower left-hand corner of the Timeline panel. Looks like a stack of squares with a check mark in the top-most square. Try clicking on that and see if your numbers reappear.
  • Joshua Sarlo
    September 11, 2015 at 6:53 pm
    THANK YOU!!!! Just had the same thing happen and you hit the nail on the head, Terry. Thanks!!!
