Activity › Forums › Adobe After Effects › numbers counting up in parenthesis (expression)
  • numbers counting up in parenthesis (expression)
    Posted by Jacques Levet on March 7, 2012 at 6:06 pm
    Hello everybody
    i m currently using an expression to have a percentage count up to a specific number. I ve got that part figured out, but i would like the percentage amount to be in between parenthesis like this : (5.07%)
    here is the expression i m using. If anyone knows how i can alter it to fit my needs, that would be great.
    Thanks in advance
    numDecimals = 2;
    commas = true;
    dollarSign = true;
    beginCount = 0
    endCount = 5.03
    dur = 4;
    t = time – inPoint;
    s = linear (t, 0, dur, beginCount, endCount).toFixed(numDecimals);
    suffix = “”;
    if (s[0] == “-“){
    prefix = “-“;
    s = s.substr(1);
    if(dollarSign) suffix += “%”;
    if (commas){
    decimals = “”;
    if (numDecimals > 0){
    decimals = s.substr(-(numDecimals + 1));
    s = s.substr(0,s.length – (numDecimals + 1));
    outStr = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i–){
    outStr += “,” + s.substr(-i*3,3);
    outStr + decimals + suffix ;
    }else{
    s + suffix;
    Jacques Levet replied 6 years, 2 months ago 3 Members · 3 Replies
  • David Ghast
    March 7, 2012 at 11:00 pm
    Well if no one can decipher that…arent expressions just java or something? You could try to ask over at devshed.
  • John Cuevas
    March 8, 2012 at 12:15 am
    numDecimals = 2;
    commas = true;
    dollarSign = true;
    beginCount = 0
    endCount = 5.03
    dur = 4;
    t = time – inPoint;
    suffix = “”;
    if (s[0] == “-“){
    prefix = “-“;
    s = s.substr(1);
    if(dollarSign) suffix += “%)”;
    if (commas){
    decimals = “”;
    “(” + outStr + decimals + suffix ;
    }else{
    “(” + s + suffix;
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jacques Levet
    July 7, 2020 at 2:29 am
    Thank you!
