Activity › Forums › Adobe Illustrator › Number of Vertices Info on a Selection?
  • Number of Vertices Info on a Selection?
    Posted by Eric Fitzgerald on March 13, 2019 at 4:54 pm
    Hello All,
    I’ve got a project the requires me knowing the exact number of vertices on a given outline. Right now I am using Object>Path>Simplify and getting the number from the Preview and then canceling the operation but that is a bit tedious.
    I am wondering if there is a more direct way to see the number of vertices on a selected path.
    If not, that would be a nice feature to add to the Info pane.
    TIA,
    Eric Fitzgerald
    Eric Fitzgerald replied 7 years, 6 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    March 16, 2019 at 3:25 pm
    Window>Document Info…
    then select “Objects” from the palette menu.
    Senior Graphic Designer
  • Eric Fitzgerald
    March 16, 2019 at 6:03 pm
    There it is!
    Thanks Kelleheikki!
