Activity Forums Adobe After Effects Number Increasing Automatically
  • Number Increasing Automatically
    Posted by Marcio Souza on October 14, 2013 at 4:07 am
    I have seen some posts here but none of them has the answer I am looking for.
    I want to make a number increasing from 0 to 28 357 561, if possible with $ at the beginning. I have seen some tutorials on youtube but all of them just teach you how to increase the number up to 1000000, if it is possible I want to keep the spaces every 3 numbers.
    John Cuevas replied 12 years, 11 months ago 2 Members · 3 Replies
  • John Cuevas
    October 14, 2013 at 1:56 pm
    Create a text layer(shift+cntl+alt+T) and make it right justified. Add the effect Expressions Control > Angle Control to the effect.
    Twirl open the text layer and alt click the source text stopwatch to open the expression dialogue and add the following expression(courtesy of Dan Ebberts). I used comma’s instead of spaces, but if you want spaces in the line “outStr += “,” + s.substr(-i*3,3)” replace the comma in quotes with space: numDecimals = 2;
    commas = true;
    dollarSign = true;
    dur = 4;
    s = effect("Angle Control")("Angle").value.toFixed(numDecimals);
    prefix = "";
    if (s[0] == "-"){
    prefix = "-";
    s = s.substr(1);
    if(dollarSign) prefix += "$";
    if (commas){
    decimals = "";
    if (numDecimals > 0){
    decimals = s.substr(-(numDecimals + 1));
    s = s.substr(0,s.length - (numDecimals + 1));
    outStr = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i--){
    outStr += "," + s.substr(-i*3,3);
    prefix + outStr + decimals;
    }else{
    prefix + s;
    I made an example project if anything is unclear: 6633_moneycounter.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Marcio Souza
    October 15, 2013 at 3:30 am
    Hey John,
    Thanks a lot, that is exactly what I was looking for and I could not find anywhere.
    You are the best!
  • John Cuevas
    October 16, 2013 at 12:29 am
    It was mostly Dan Ebberts who did, but I’m glad I was able to pass it on.
    Thinkck.com
