Activity Forums Adobe After Effects Expressions Number counter with comma
  • Number counter with comma
    Posted by Adam Zygadlo on September 7, 2016 at 9:48 am
    Good morning everyone,
    I wonder if anyone can help out with this issue. At present, I have built a number counter that builds up from 0 to 150k. I sent the animation to the client for review and they came back with a feedback, where they want to place a comma in the number like 34,843.
    The way I built the project so far was using the text layer and link the source settings to a slide control to animate the numbers using this expression:
    n = comp(“LINK TO SLIDER”);
    d = 1;
    Math.round(n*d)/d;
    Is there a way to update this expression, where the numbers has the comma within the text? (23,289, 56,239, 100,000)
    Thank you in advance,
    Addz
    n = comp("LINK TO SLIDER");
    d = 1;
    Math.round(n*d)/d;
    Adam Jozef Zygadlo
    Motion Graphic Designer
    07708 124 915
    http://www.jarbrain.com
    ‘Filled with brainy goodness.’
    Tom Davis replied 5 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Adam Zygadlo
    September 7, 2016 at 10:34 am
    Alright, I spent some time browsing on this forum, find a great expressions from Dan Ebberts (https://forums.creativecow.net/readpost/227/16453) which that did the trick.
    n = 0+comp(“LINK TO SLIDER”);
    s = “” + n;
    str = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i–){
    str += “,” + s.substr(-i*3,3);
    str
    However, it has now caused another problem where the numbers goes all werid like ‘9,234,6.6,875’. Ideally, it would be great to round up the number to 91,607. :^)
    Adam Jozef Zygadlo
    07708 124 915
  • Adam Zygadlo
    September 7, 2016 at 11:14 am
    Awesome, I have solved the original problem as well as the new issue when introducing new expressions.
    Basically, I added another slider control between the text layer to the main slider to round up the number. Here’s a breakdown to the expressions, etc.
    Text Layer: Source
    n = 0+effect(“Slider Control”)(“Slider”);
    s = “” + n;
    str
    The code above links to the new slider, which is applied to the text layer:
    n = comp(“LINK TO MAIN SLIDER”);
    d = 1;
    Math.round(n*d)/d;
    I am pretty sure there’s a simpler way to get this expression but I am happy that I have solved it myself. :^D
    Thank you!
    Addz
    Adam Jozef Zygadlo
    07708 124 915
  • Kalleheikki Kannisto
    September 7, 2016 at 1:07 pm
    Perfectly valid solution. Yes, you could do it without the intermediate slider, but hey, where’s the fun in that?
    Senior Graphic Designer
  • Dan Ebberts
    September 7, 2016 at 1:09 pm
    Try this:
    Math.round(n).toString().replace(/\B(?=(\d{3})+(?!\d))/g, “,”);
    Dan
  • Adam Zygadlo
    September 7, 2016 at 2:25 pm
    Thank you Dan. The expression looks so much cleaner. Defo will save this line of code for future projects but I’ll stick to my version for now. ;^)
    Thanks again to everyone!
    Cheer,
    Addz
    Adam Jozef Zygadlo
    07708 124 915
  • Liran Tabib
    May 10, 2018 at 6:57 am
    If you wish to skip the expression method, you can also use Counter Preset to create any Counter and running numbers animation, with all kinds of Dividers (, . ‘ etc.). I hope you will find it useful. you can get it here:
    https://www.vdodna.com/products/counter-preset/
    Cheers!
    Liran Tabib
    http://www.vdodna.com
  • Tom Davis
    July 19, 2021 at 9:15 am
    With the new Javascript engine in AE you can now do the following:
    First add an angle control to your text layer, then add the following expression to your sourcetext value:
    var num = parseFloat(effect("Angle Control")("Angle")); num.toLocaleString("en-GB");
    The .toLocaleString option also comes with some other options like percentage signs and different separators depending on the parameters you pass to the function. If you’re interested, I wrote more about these different features in this blog on creating a number counter with commas
