Number counter speed change question
Hello,
I have made this number ticker using point control and a specific code. This causes the ticker to change numbers rapidly per frame. I’m trying to figure out a way to change the rate of the numbers changing so it’s not as fast. I’ve attached a clip of what I have currently and screenshots of the composition with the code visible. Thanks for your help!
