Activity Forums Adobe After Effects Expressions Number counter expression
  • Number counter expression
    Posted by Nick Doyle on March 4, 2019 at 12:53 pm
    Hello,
    I’m working on a project and I’ve got a basic number counter set up to display the number 1213.37. I’ve used the following expression:
    effect(“Slider Control”)(“Slider”).valuetoFixed(2)
    I need to change the format of the number to this:
    1,213.37
    I’ve used this piece of code to add the coma in:
    var num = effect(“Slider Control”)(“Slider”)
    num = Comma(num);
    [num]
    function Comma(number)
    number = ” + Math.round(number/10);
    if (number.length > 3)
    var mod = number.length % 3;
    var output = (mod > 0 ? (number.substring(0,mod)) : ”);
    for (i=0 ; i < Math.floor(number.length / 3); i++)
    if ((mod == 0) && (i == 0))
    output += number.substring(mod+ 3 * i, mod + 3 * i + 3);
    else
    output+= ‘,’ + number.substring(mod + 3 * i, mod + 3 * i + 3);
    return (output);
    else return number;
    I can’t seem to figure out how to adjust it to move the comma and put the decimal point back in. Any help and advice would be very much appreciated.
    Liran Tabib replied 7 years, 3 months ago 3 Members · 9 Replies
  • 9 Replies
  • Oleg Pirogov
    March 4, 2019 at 1:30 pm
    This:
    var parts = number.toString().split(".");
    gives you an array [‘1213′, ’37’], so you can apply your comma-separating function to parts[0] getting [‘1,213′, ’37’] and then rejoining them with:
    parts.join(".");
    Just for a reference, a regex code which does what you want:
    function numberWithCommas(x) {
    var parts = x.toString().split(".");
    parts[0] = parts[0].replace(/\B(?=(\d{3})+(?!\d))/g, ",");
    return parts.join(".");
    which I’ve found here: https://stackoverflow.com/questions/2901102/how-to-print-a-number-with-commas-as-thousands-separators-in-javascript
  • Nick Doyle
    March 4, 2019 at 1:43 pm
    Ooo thank you, can’t seem to find the correct point to add this in though. Here is what I tried:
    num = Comma(num);
    [num]
    var parts = x.toString().split(“.”);
    parts[0] = parts[0].replace(/\B(?=(\d{3})+(?!\d))/g, “,”);
    return parts.join(“.”);
    else
    return (output);
    else return number;
  • Oleg Pirogov
    March 4, 2019 at 1:58 pm
    It’s an alternative to your function, so:
    var num = effect("Slider Control")("Slider")
    num = numberWithCommas(num);
    [num]
  • Nick Doyle
    March 4, 2019 at 2:32 pm
    Sorry I’m a bit confused I’ve pasted it in place of my function and now the number turns into the word ‘object’
  • Oleg Pirogov
    March 4, 2019 at 2:48 pm
    Can you post the whole expression?
  • Nick Doyle
    March 4, 2019 at 3:12 pm
    Here it is. I replaced the existing function with below:
    parts[0] = parts[0].replace(/\B(?=(\d{5})+(?!\d))/g, “,”);
    [num]
  • Oleg Pirogov
    March 4, 2019 at 3:27 pm
    Yeah, it’s effect(“Slider Control”)(“Slider”).value
    This should work:
    var num = effect("Slider Control")("Slider").value
    [num]
  • Nick Doyle
    March 4, 2019 at 4:21 pm
    Perfect! Thanks so much for your help.
  • Liran Tabib
    May 16, 2019 at 10:36 am
    If you wish to skip the Expressions and you have few buck to spare you can always use Counter Preset
    Cheers!
    Liran Tabib
    http://www.vdodna.com
