Activity › Forums › Adobe After Effects › Number Count up
Number Count up
Posted by Yoshi on October 14, 2005 at 7:32 pmHi, all.
I need help for Number Count Up graphic.
Basically, I need to make Count up graphic from $100 to $1000 in a couple sec.
So, I think I need to have some script which count up from 100 to 1000.
Does anyone know how to do it?Thanks, Yoshi.
Mari Nieminen replied 14 years, 4 months ago 8 Members · 8 Replies -
Dan Ebberts
October 14, 2005 at 8:30 pmA text expression like this should get you started:
beginTime = 0;
endTime = 2;
startVal = 100;
endVal = 1000;“$” + Math.round(linear(time,beginTime,endTime,startVal,endVal))
Dan
Matt Larson
October 14, 2005 at 9:03 pmThank you for that! That’s one of those things I struggled through doing manually a year ago….guess I should have posted here!
Another new addition to my bag of tricks courtesy of the COW
Ariel Brener
July 15, 2009 at 9:17 amWorks great thanks!
Now let me challenge you!
how do you EASE to the target number?٩(̾●̮̮̃̾•̃̾)۶
ADOBE MASTER COLLECTION CS4
Win Vista Ultimate 64bit
RAM: 8GB (Corsair 800Mhz)
CPU: Intel Quad Core 2.4Ghz (Q6600)
GPU: ATI x1950XT 256MB
MB: Asus P5K Deluxe WiFi-AP -
Aqeel Fikree
July 27, 2009 at 7:28 pmHi, I’ve used your count up expression and it works like a charm. Can I add something to change the figures in steps of let’s say 10s or 100s.
Thanks.
Brad Magnus
March 24, 2012 at 10:46 pmThis thread is 2 years old now, but I spent the better part of a couple hours looking for an answer, so I thought I’d post what I did here.
In order to ease into the final number, I used the built in feature of AE, Numbers. That way I had access to keyframes, and my usual ways of controlling easing (ie. eaze and wizz)
Mari Nieminen
May 23, 2012 at 10:17 amI also tried using the text effect numbers and here comes the but. I am using sure target to control the camera and I do not know why, but the number effect “do not line up”. In the effect control panel, there is no z value for the position which makes me think the effect does not work with camera (which can not be…).
I have one main comp where I have “sub-comps”, all layers 3D turned on (and continuously Rasterize). Everything else work fine but the text effect numbers. They act as if being regulas 2D layers. Any ideas…?
