Activity Forums Adobe After Effects Expressions Number Count Past 30,000
  • Number Count Past 30,000
    Posted by Lisa Ruiz on October 2, 2009 at 12:02 am
    I’m trying to do a number count up that goes to 45,050. I’ve tried an expression that uses the slider but I keep getting errors that disable the expression. It needs to count up from 0 to 45,050 and I need it to have the comma. Also I would like it to start when the layer starts not the comp, and have a duration line. Here’s the expression I was trying to use-
    s = effect("value")("Slider");
    m = effect("multiplier")("Slider"); //use for numbers greater than 1 million
    v = s*m; //value of counter
    function digits(Val, Digits)
    {var n = Val.toString();
    while (n.length < Digits) n = '0' + n; return n;}
    h = Math.floor(v);
    t = Math.floor(h / 1000);
    m = Math.floor(t / 1000);
    hd = digits(h-t * 1000, 3);
    td = digits(t-m * 1000, 3);
    if (v < 1000) {h} else if (v < 1000000) {t + "," + hd} else {m + "," + td + "," + hd}
    Wil Magness replied 14 years, 5 months ago 2 Members · 1 Reply
  • Wil Magness
    March 8, 2012 at 9:09 am
    If anyone else is looking for a solution to this problem, I believe you just need to change the single quotes around the zero, to double quotes.
    You would change:
    while (n.length < Digits) n = ‘0’ + n; return n;}
    to:
    while (n.length < Digits) n = “0” + n; return n;}
