Activity Forums Adobe After Effects Expressions Number between (1-30)
  • Number between (1-30)
    Posted by Scott Mcgee on June 14, 2017 at 2:27 pm
    I’ve got this expression.
    input = thisComp.layer(“^Leeds Day One”).text.sourceText.toLowerCase();
    if (input.indexOf(“maximum temperature: 1°c”) != -1) {“1”}
    else if (input.indexOf(“maximum temperature: 2°c”) != -1) {“2”}
    else if (input.indexOf(“maximum temperature: 3°c”) != -1) {“3”}
    else if (input.indexOf(“maximum temperature: 4°c”) != -1) {“4”}
    else if (input.indexOf(“maximum temperature: 5°c”) != -1) {“5”}
    else if (input.indexOf(“maximum temperature: 6°c”) != -1) {“6”}
    else if (input.indexOf(“maximum temperature: 7°c”) != -1) {“7”}
    else if (input.indexOf(“maximum temperature: 8°c”) != -1) {“8”}
    else if (input.indexOf(“maximum temperature: 9°c”) != -1) {“9”}
    else if (input.indexOf(“maximum temperature: 10°c”) != -1) {“10”}
    else if (input.indexOf(“maximum temperature: 11°c”) != -1) {“11”}
    else if (input.indexOf(“maximum temperature: 12°c”) != -1) {“12”}
    else if (input.indexOf(“maximum temperature: 13°c”) != -1) {“13”}
    else if (input.indexOf(“maximum temperature: 14°c”) != -1) {“14”}
    else if (input.indexOf(“maximum temperature: 15°c”) != -1) {“15”}
    else if (input.indexOf(“maximum temperature: 16°c”) != -1) {“16”}
    else if (input.indexOf(“maximum temperature: 17°c”) != -1) {“17”}
    else if (input.indexOf(“maximum temperature: 18°c”) != -1) {“18”}
    else if (input.indexOf(“maximum temperature: 19°c”) != -1) {“19”}
    else if (input.indexOf(“maximum temperature: 20°c”) != -1) {“20”}
    else if (input.indexOf(“maximum temperature: 21°c”) != -1) {“21”}
    else if (input.indexOf(“maximum temperature: 22°c”) != -1) {“22”}
    else if (input.indexOf(“maximum temperature: 23°c”) != -1) {“23”}
    else if (input.indexOf(“maximum temperature: 24°c”) != -1) {“24”}
    else {0}
    I want to compress it to something more like below.
    n = ?
    if (input.indexOf(“maximum temperature: “+n+”°c”) != -1) {“”+n+””}
    else {0}
    sourceText will change, so I can’t use substr. So i’m using indexof and want to array or for loop n = ?
    Rather than my current expression
    Any ideas?
    Dan Ebberts replied 9 years, 2 months ago 2 Members · 1 Reply
  • Dan Ebberts
    June 14, 2017 at 4:05 pm
    One way:
    input = thisComp.layer("^Leeds Day One").text.sourceText.toLowerCase();
    result = 0;
    for (var i = 1; i <= 24; i++){
    if (input.indexOf("maximum temperature: " + i + "°c") > -1){
    result = i;
    break;
    result
    Dan
