Activity › Forums › Adobe After Effects › Number animation from CVS
  • Number animation from CVS
    Posted by Roy Metni on June 23, 2023 at 2:25 pm
    I have this expression and it’s working normally . the thing is, It’s only reading from Column 1 in the CSV. I want it to read from column 2 . What should I modify in this expression ?
    _column = 0;
    _row = time*30;
    _sliderValue = footage(“Stats.csv”).dataValue([_column,_row])
    Graham Quince replied 3 years, 3 months ago 2 Members · 1 Reply
  • Graham Quince
    June 24, 2023 at 12:57 pm
    I’m guessing its not your expression, so I’m going to feel free to critise it for poor style choice for variables names 😜
    But the top line _column looks like its the variable you want to change.
    Personally, I think the safest option here is to add a slider (hit ENTER and rename it to “Column Slider” to your layer and then use this version of the expression:
    var column = praeInt(effect("Column Slider")("Slider"));
    var row = time*30;
    var sliderValue = footage(“Stats.csv”).dataValue([column,row])
    Then you can set the column to 0, 1, 2 etc…
