Activity Forums Adobe After Effects Expressions Nulls from pins then parent the pins to eachother script
  • Nulls from pins then parent the pins to eachother script
    Posted by Sam Catt on May 14, 2018 at 11:15 am
    Hi, i’m building my first script and need a little bit of help… I’m trying to make it so I get the null’s from pins and connect them as controllers. Then parent the nulls to eachother, but making the top most null.parent=null
    I’ve got the first part working.
    app.beginUndoGroup("Create Nulls for Pins");
    var theComp = app.project.activeItem;
    if (theComp == null || !(theComp instanceof CompItem)){
    alert(errorNoCompSelected);
    } else {
    var theLayers = theComp.selectedLayers;
    if (theLayers.length==0) {
    alert(errorNoLayerSelected);
    } else {
    for (var i = 0; i < theLayers.length; i++){
    var curLayer = theLayers[i];
    // condition 1: must be a footage layer
    if (curLayer.matchName == "ADBE AV Layer"){
    //condition 2: must be a 2D layer
    if (!curLayer.threeDLayer) {
    //condition 3: must have puppet pins applied
    if (curLayer.effect.puppet != null) {
    var wherePins = curLayer.property("Effects").property("Puppet").property("arap").property("Mesh").property("Mesh 1").property("Deform");
    var pinCount = wherePins.numProperties;
    for (var n = 1; n <= pinCount; n++) {
    // Get position of puppet pin
    try {
    var pin = curLayer.effect("Puppet").arap.mesh("Mesh 1").deform(n);
    //var solid = theComp.layers.addSolid([1.0, 1.0, 0], nullName, 50, 50, 1);
    var solid = theComp.layers.addNull();
    //solid.name = pin.name + "_ctl";
    solid.name = curLayer.name + "_" + pin.name;
    //scaled from layer coords to world coords
    var p = pin.position.value;
    solid.property("position").setValue(harvestPoint(p, curLayer, solid, "toComp"));
    var pinExpr = "fromComp(thisComp.layer(\""+solid.name+"\").toComp(thisComp.layer(\""+solid.name+"\").anchorPoint));";
    pin.position.expression = pinExpr;
    } catch(err) {}
    curLayer.property("Effects").property("Puppet").property("On Transparent").setValue(1);
    curLayer.locked = true;
    } else {
    alert("Layer must have puppet pins.");
    } else {
    alert("Layer must be 2D.");
    } else {
    alert(errorFootageOnly);
    app.endUndoGroup();
    and i’m trying to combine it with
    if (i == 0) {
    for (var j = 0; j < theLayers.length; j++){
    if(theLayers[i].parent==theLayers[j]) theLayers[i].parent=null;
    } else {
    theLayers[i].parent = null;
    theLayers[i].parent = theLayers[i-1];
    But for the life of me, I can’t get it work correctly. I would of included it into the creation of the null objects but then the others don’t exists so I’m unable to parent them. Also creating it after the nulls have been created I’m not sure how to select the nulls to parent them together. I thought of trying to find their names and parent them one at a time, but it hasn’t worked for me yet
    Any help on this would be amazing
    Steven Perry replied 8 years, 3 months ago 2 Members · 1 Reply
  • Steven Perry
    May 18, 2018 at 11:53 pm
    This sounds like creating bones in the plugin DUIK, and then auto rigging an arm.
    It’s free. Check it out.
