Activity Forums Adobe After Effects Nulls and Parenting
  • Nulls and Parenting
    Posted by Chip Hess on August 12, 2022 at 10:08 pm
    So I have a piece of footage on which I got a nice stable track. Created null. Created some text. Null is parent to the text. However, the text is not staying in the part of screen I want. I imagine something to do with positioning of Null…?
    Chris Abolt replied 4 years, 1 month ago 2 Members · 1 Reply
  • Chris Abolt
    August 14, 2022 at 1:22 am
    The text should be parented to the null. Open the positing parameters of the null X,Y,Z and copy/paste this to the text layer’s X,Y,Z to locate it exactly where the null is in 3D space. If you don’t see Z axis available on your text then it needs to be converted to 3D text first before copying the parameters. Once you locate the text to the same location of the null and parent it, you can delete the keyframes for the X,Y,Z on the text layer. It will use the Null’s positioning at that point. The null also needs to be 3D but it already probably is from the track.
    Thanks Chris
