Activity Forums Adobe After Effects nulls and cameras
  • nulls and cameras
    Posted by Michael Jurkowski on April 14, 2008 at 10:05 pm
    Hi everyone,
    I have a sequence where I created streaks using fractal noise and (kinda sorta like Kramers Serious FX tutorial) and I want random words to rotate around it. Now I’ve gotten the words in place and everything is set…however, when I rotate using a null object (I’ve parented all the words to the null object) I find that I cannot rotate them in a 3D environment…how can I do this? Again, I have the words rotating around this streak.
    Michael Jurkowski replied 18 years, 4 months ago 2 Members · 2 Replies
  • Darby Edelen
    April 15, 2008 at 7:49 am
    [Michael Jurkowski] “Now I’ve gotten the words in place and everything is set…however, when I rotate using a null object (I’ve parented all the words to the null object) I find that I cannot rotate them in a 3D environment…how can I do this? Again, I have the words rotating around this streak.”
    Is your Null a 3D layer? Is your text a 3D layer? What exactly about ‘them’ (the nulls or the text?) is not allowing you to rotate in a 3D environment?
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Michael Jurkowski
    April 15, 2008 at 2:20 pm
    I have my null and text set as 3d layers…I parented the text layers to the null object so they can all move together, the only problem is when I want to rotate the text, I want it to rotate in like a circle around this streak, but when I rotate the text they look 2D, so in order for me to make it so the text are not 2d, I have to individually rotate/scale the text myself as they move around this streak.
