Activity Forums Adobe After Effects Null objects and transparency
  • Null objects and transparency
    Posted by Joe Bodego on August 13, 2015 at 8:25 am
    Is it possible to control the transparency with a null object. I know you can scale, rotate etc but i have no luck with transparency. Is there a work around?
    Joe Bodego replied 11 years ago 2 Members · 2 Replies
  • John Cuevas
    August 13, 2015 at 1:09 pm
    Add a Slider Control effect to the Null object, then just pick whip the child objects opacity(alt-click opacity stopwatch to enable expression) to the slider.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Joe Bodego
    August 13, 2015 at 6:23 pm
    Thank you, your answer helped, now it worked
