Activity › Forums › Apple Final Cut Pro Legacy › Null Object / Null Layer
Posted by Dustin Parsons on February 19, 2009 at 7:34 pmIs there any way to create a null object (like After Effects’ Null Objects) that I could add a vignette to?
Mac Pro | Leopard 10.5.5
2.66GHz Dual-Core Intel Xeon | 4GB Ram
Final Cut Pro Studio 2 | Avid Media ComposerMichael Brassert replied 16 years, 4 months ago 6 Members · 6 Replies -
Dennis Leppell
February 19, 2009 at 8:35 pmNope, but a new color solid + mask shape, mask feather, and maybe opacity and/or composite mode should get the job done
Arnie Schlissel
February 19, 2009 at 8:54 pmYou can use the “slug” for this. It’s a generator that will place a black clip in your timeline.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Dustin Parsons
February 19, 2009 at 9:57 pmDarn… why can’t FCP and AE be one program?
Thanks for the speedy reply.
Final Cut Pro Studio 2 | Avid Media Composer -
David Bogie
February 19, 2009 at 10:40 pm[Dustin Parsons] “Is there any way to create a null object (like After Effects’ Null Objects) that I could add a vignette to?
“A vignette applied to a null would be just as invisible as the null.
bogiesan
Jeremy Garchow
February 20, 2009 at 1:18 amEffects > Video Filters > Stylize > Vignette
Or add an oval shape generator under an export the whole program and track matte the top layer.
Michael Brassert
May 21, 2010 at 5:50 pmI just did this. I nested a clip and applied a filter to the nested clip. Worked great. In my case I had a SD clip in an HD sequence. I wanted the filter (SugarFX HUD) rendered in HD not SD. I would expect this to work with a vignette as well.
(I reserve the right to be wrong)
Michael
