Activity Forums Maxon Cinema 4D null object not animating
  • null object not animating
    Posted by Brad Goosen on August 27, 2009 at 6:23 am
    hey guys
    i’m having problems with animation. i’ve created a null object with various things attached to it. i want to animate the rotation. i create a key frame for frame 1 and then a key frame for the last frame. problem is nothing happens.
    when i look at the timeline it looks like the key frames values are increasing, but in the attributes manager it looks like the key frames have the exact same value. is there a way i might have selected both keyframes and i’m change both at once?
    i’m running c4d r9.6 on a mac pro osx 10.5.8
    thanks in advance
    brad
    An Wartersion replied 10 years, 4 months ago 3 Members · 4 Replies
  • Brad Goosen
    August 27, 2009 at 6:33 am
    oddly when a render out the file the animation is working, however it doesnt render any animation updates when i render the active view
    very strange… i’ve been working with c4d for a while and haven’t had this problem before
  • Adam Trachtenberg
    August 27, 2009 at 3:49 pm
    Did you turn off “use animation” in the edit menu?
  • Brad Goosen
    August 28, 2009 at 12:04 am
    hmmm… that’s exactly what i did
    thanks adam… you’re a genius
    brad
  • An Wartersion
    April 29, 2016 at 11:08 am
    i’m having the same problem but only one object aren’t moving and everythingelse is moving just fine.
