Activity Forums Adobe After Effects NULL object follow animated mask
  • NULL object follow animated mask
    Posted by Stefan Saw on April 4, 2017 at 2:04 pm
    Hello,
    I try to let a NULL object follow a animated mask but AE keeps crashing/freezing.
    I generate a mask from a alpha channel (auto trace) copy the mask path postion and paste it into the postion of the NULL object. But AE seems to not like it, and keeps freezing. The mask animation is 3 sec. long in that try out version, later it will be much longer.
    My aim is to let particle emitter along the mask path.
    What Im doing wrong? Is there any workaround? Is it me or is it AE?
    EDIT: OK it seems there is a collision between the path animation and the null object follow. I tried a very simple 5 point animated path and the null follows, but in a kind of weired way…
    Stefan Saw replied 9 years, 5 months ago 2 Members · 3 Replies
  • Richard Garabedain
    April 4, 2017 at 2:46 pm
    that is strange…maybe you could try selecting a point on the mask and going to layer-set first vertex and see if that helps at all.
  • Stefan Saw
    April 4, 2017 at 4:20 pm
    Here I did a quick screenshot video. First you can see short the mask my real try out project. The original will be much longer.
    https://youtu.be/FwEdNOnefEY
    Hope that helps to understand whats not working here. It seems that the path double itself? The original and the animated?
  • Stefan Saw
    April 4, 2017 at 5:24 pm
    Thanks for your replay. Good to know.
    OK than back to Plan B.
    I just create a thin (out)line of a layer with two animated mask, and let particular use the thin line layer as a emitter.
    I still prefer to have both option, but if it cant be done…it cant be done .. ????
    Ill post the final, once its done….
    thx
