Activity › Forums › Adobe After Effects Expressions › Null and Camera?
Null and Camera?
Posted by Jon Herron on March 2, 2006 at 5:40 amWhen I use a null object for camera movements, do you use the position of the null as the POV of the camera? or do you actually place the camera on the position of the null??
thanks guys,
jonJon Herron replied 20 years, 6 months ago 4 Members · 4 Replies -
Guy
March 2, 2006 at 2:48 pmyou can do either with an expression.
However, I parent a Camera to a null when I want to animate Position and POV at the same time. It’s easier I find. -
Ryan Hill
March 2, 2006 at 2:59 pmThat would depend on what kind of movement you’re trying to achieve. Normally, you won’t use a null at exactly the same point as either the camera or the point of interest or it would be redundant. More likely, you’ll set the anchor point somewhere you want to rotate around, though there’s a lot of other things you can do with that.
You might pick-whip the camera’s position to the position of the null, which isn’t redundant, because the camera would still use its own rotation values. Or you can set the null as the parent of the camera, and then it also rotate with the null.
Chris Smith
March 2, 2006 at 3:23 pmDepends how you want to use it. For example if you want your camera to do a perfect circle orbit. Parent it to a null. Set the null a distance away from the cam. Now rotate the null. The cam will now orbit it.
I always move a camera by parenting it to a null and keyframing the null so the cam has all of it’s parameters always clear for keyframing independantly. I also turn off the camera’s auto orient function so it’s not always trying to look at the POI.
Chris Smith
https://www.sugarfilmproduction.com -
Jon Herron
March 2, 2006 at 8:12 pmCool thanks for the help, I’ve always just done a direct camera parent to the null. And move the null for the camera movement. Just curious if I was doing it properly. Thanks guys
jon
