Activity › Forums › Adobe After Effects › Nuke camera to After Effect….. ??
Posted by Niccolò Ungaro on August 9, 2011 at 11:55 pmI will like to export all camera data from Nuke to After Effect…any suggestion???
Thank you & regards.
Nic.Niccolò Ungaro replied 15 years, 1 month ago 3 Members · 4 Replies -
Tudor “ted” jelescu
August 10, 2011 at 10:40 amNot sure if a straight export is possible, but you could use Camera Tracker from The Foundry in AE to extract cam data from a rendered clip in Nuke. It’s a work around, I know, but is the only idea I have- maybe someone else can give you a better solution.
Tudor “Ted” Jelescu
Senior VFX Artist -
Darby Edelen
August 10, 2011 at 5:33 pmAs far as I know the only way to export camera data out of Nuke is in a .chan file. Maya can open that, and then you can save the scene as a .ma file that AE should be able to import.
You may run into some issues with frame sizes and unit conversions, but that’s the closest I can come up with off the top of my head.
Darby Edelen
Tudor “ted” jelescu
August 10, 2011 at 6:38 pmElegant option- did not think of that one.
Tudor “Ted” Jelescu
Senior VFX Artist
