Activity › Forums › Avid Media Composer › Nuendo BWAVs into MC 8.5.3
  • Nuendo BWAVs into MC 8.5.3
    Posted by Neil Ryan on August 25, 2016 at 3:56 am
    I was wondering if there are any Media Composer users out there who are often integrating BWAVs made from Nuendo.
    I can successfully Link to BWAVs made from ProTools without any problem, and have been for quite a while, through various versions of MC.
    I haven’t had to Link to files from Nuendo for some time, but I am now and will be for some time to come, on a new series.
    Check my system details but please be aware that my MC is within an Interplay environment (which colours some issues.)
    Currently, when I Link to a wav from Nuendo, I get this error immediately:
    The file is playable and can be edited into a Sequence, but overtime I check in the file or sequence, the error comes up again.
    My workaround is to simply import the file and use it in the same way.
    I don’t know where the error is – MC, Interplay or Nuendo – and although I can import the files and make them work, I need to send these files to external clients, so I need to know that they will not have the same/similar problems with them, in MC or any other application.
    Thoughts anyone?
    Neil Ryan
    Senior Finishing Editor
    WTFN
    OS 10.11.4 Mac Pro
    Media Composer 8.5.3 with Symphony & Interplay 3.4 AvidFX 6.4
    Neat Video 4.1.4 ISIS5500
    Michael Phillips replied 10 years, 1 month ago 2 Members · 1 Reply
  • Michael Phillips
    August 25, 2016 at 5:55 pm
    It may be an issue of AMA audio linking and the check in process. Personally I import all audio all the time as I need to 1/4 frame sync which linking/consolidation/transcode does not allow, but that may not be a need in your case.
    Michael
