Activity › Forums › DaVinci Resolve › nudging IO
  • nudging IO
    Posted by Alex Gat on January 11, 2018 at 2:17 pm
    Hello,
    Sorry if the question is a bit dumb but, I have those clips where I already have set input and output.
    Now I need to move the io respectively by an exact amount of frame. Don’t ask why…
    what I want to do is a bit like using the trim edit tools in the timeline.
    Is there a way to select a clip and nudge its IO point by an exact amount of frame ?
    Right now, I use a freeware that allows me to calculate the new entry point, then I move the playhead to that timecode and set the input again, then I do the output. A burden.
    I hope I have been clear.
    Alex
    Glenn Sakatch replied 8 years, 8 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    January 11, 2018 at 4:15 pm
    Do you want to slip the footage inside the clip you’ve already edited? The slip command can do that.
  • Alex Gat
    January 11, 2018 at 4:25 pm
    Thanks, yes this is what I want to do, but with a precise number of frame. Where is the slip command you are talking about. There are slip commands in the Trim menu, but they do not offer to enter a desire number of frame.
  • Tero Ahlfors
    January 11, 2018 at 4:39 pm
    Read page 420 and forwards in the manual.
  • Glenn Sakatch
    January 13, 2018 at 8:30 pm
    I’m assuming you haven’t built your timeline yet? Otherwise, you would have to re-edit every shot again, if all you do is move the In and Out point. If that is what you want to do, it would be a pretty simple macro to build, assuming you are moving either the in or the outs by the same number for each clip.
    Macro would simply record the following keystrokes.
    -go to in
    – minus 5
    -mark in
    go to out
    -plus 6
    mark out
    Glenn
