Activity Forums Adobe After Effects Nucleo, Purging & Ram
  • Nucleo, Purging & Ram
    Posted by Dan Lachevre on September 21, 2006 at 8:21 am
    I have read a number of the posts and articles relating to RAM and haven’t found answers to a couple of questions.
    My issue is I have an AE6.5 project that keeps falling over due to RAM issue:
    -After Effects warning: memory inefficiency due to 2 unbalanced checkouts ( 26 & 248 )
    -After Effects: not enough memory to create U_MemTrackedObject. (1K requested, 0K available)
    – After Effects Error: Failure during Render (4) ( 25& 60 )
    My setup is
    -a Quad G5 with 4.5 gigs of Ram and AE6.5.1 & INVIG 4.8
    The weird thing is I get the first frame rendered each time I set it off then it falls over with the FAILURE error. It sounds like a maxed out RAM prob but I have the secret setting to purge every frame and tried a few different Ram cache settings which I imagine are over ridden anyway.
    So my questions are:
    01. What is the magic fix?
    02. With the 2g limit and the way Nucleo works [ I don’t have it] I imagine I would just get 4 frames before it fell over. Does this sound right?
    03. If a project falls over due to RAM issues Nucleo will not fix this as it just better utilizes the processors/writing to disk when rendering which results in a speed increase. Is this right?
    Danny
    Dan Lachevre replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
