Activity Forums Adobe After Effects Nucleo Pro + Knoll Pro 2.5 = Bad?
  • Nucleo Pro + Knoll Pro 2.5 = Bad?
    Posted by Nicholas Toth on May 23, 2007 at 3:19 am
    So I finally narrowed down why nucleo pro is failling 100%. Because I’m using Knoll (a lot…its cool stuff and the client loves it). I just re-installed everything, and ran some tests without knoll, and the renders went pretty darn quick. As expected.
    THEN as another test I put knoll on a layer in a comp, set a wiggle to the position of the flare (so it isn’t boring), put another layer below it and slapped on one of those hokey effects — I think it was the flowing gold preset. Queued it. Nucleo crashed. Then I just hid the knoll layer, queued it, Nucleo crashed. Then I physically deleted the knoll layer, queued it, and Nucleo went right through it all.
    Is this happening to anyone else? I’m running a macbook with 2 gigs of ram. My bootcamp is all updated, and everything software wise is up to date and running well. This of course is on the windows end of the machine.
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
    Paul Hamrick replied 19 years, 1 month ago 2 Members · 2 Replies
  • Nicholas Toth
    May 23, 2007 at 3:21 am
    Let me clarify, has been failling. Nucleo Pro is the best thing since sliced bread in my mind when it comes to new(er) software for AE. I’m looking forward to purchasing NP2 also.
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
  • Paul Hamrick
    August 1, 2007 at 4:38 pm
    I’m having the same problem!
    NP2 and Light Factory 2.5 crashes both NP2 and AE CS3. Just applying the plug crashes AE, I don’t have to send it to render. If any of the spec previews or renders are enabled in Nucleo – it crashes too.
    No solutions (or response) from support yet.
