Activity › Forums › Adobe After Effects › Nucleo Pro f’in everything up with Premiere projects
  • Nucleo Pro f’in everything up with Premiere projects
    Posted by Alfonso Gamez jordano on January 3, 2008 at 11:24 pm
    Hi again.
    I’ve got a problem with Nucleo Pro (AFX CS3).
    Normally, it will render correctly, at half time than normal rendering, and it’s been well worth the money…
    But I just had done VFX projects since I installed it. Today I imported a Premiere Pro project, and Nucleo started messing things up.
    The problem is, when I start processing any render which any premiere project files inside, Nucleo will change every single original (inside the PPro project Bin) source file’s path, by adding a \\?\ at the start of it’s path.
    So, if my footage was in
    C:\Documents and settings\footage\shjdi.avi
    After starting rendering with nucleo it’ll change to:
    \\?\C:\Documents and settings\footage\shjdi.avi
    And this results in, firstly, that nucleo renders out a fine, nicely color corrected, color test chart, and, secondly, the whole project is f’ed up and I have to manually restore every files path to it’s original…
    And the point is, this only happens with PPro projects, and when rendering with Nucleo…
    What’s causing the problem? Any guess on how could I solve it?
    Regards
    Chris Cooke replied 18 years, 9 months ago 2 Members · 1 Reply
  • Chris Cooke
    January 4, 2008 at 7:42 pm
    Alfonso,
    Are you importing the PPro project into the AE project so that there is a folder with all the footage and comps for each PPro sequence or simply grabbing rendered output from PPro into AE?
    What version of Windows and Premiere Pro are you using?
    What format is the footage?
    You can contact us at support@gridironsoftware.com for a more direct discussion,
    Chris
    GridIron Verification and Support
