Activity › Forums › Adobe After Effects › Nucleo Pro & bit-depth
  • Nucleo Pro & bit-depth
    Posted by Steve Drew on September 20, 2006 at 3:48 am
    Hiya all,
    When using the Nucleo Pro background renderer (which is just the shizzizle), I only ever see “8 bits per channel” under the Color Depth statistic, even though I’m rendering (or should be) in 32bit?
    Is that just a display bug on Nucleo’s behalf or does it not support bit depth greater than 8 bit?
    I did ‘RTF(Nucleo)M’ but came up trumps.
    Steve Drew replied 20 years ago 4 Members · 4 Replies
  • Mylenium
    September 20, 2006 at 5:36 am
    May be just a bug. Since Nucleo uses fully fledged background instances of AE, I don’t see why it should not render 32 bpc. I know that 16 bpc works just as expected, but never tried 32 bpc with it yet. Have you checked the resulting footage?
    Mylenium
    [Pour Myl
  • Steve Forde
    September 20, 2006 at 2:35 pm
    This is a UI bug. This is display only – the render is still being done at 32bit or 16 bit depending on your settings. We are shipping a patch to Nucleo Pro and Nucleo in about a week that will address this among other things.
    Steve
    GridIron Software Inc.
  • Danny Princz
    September 20, 2006 at 4:36 pm
    ill just second the background render part…
    its XXXXing awesome, though i have very little free time now :-/
    had a render that took 4.5 hours friday, installed Nuc Pro monday, and it rendered the same piece in 2.25 hours IN THE BACKGROUND while i was working!!!
  • Steve Drew
    September 21, 2006 at 12:35 am
    Thanks for the response Steve, I thought it would just be a display thing as all my renders look as they should.
    You guys have a damn fine product on your hands and I look forward to the patch next week.
    (hopefully it will sort out the EPS issues too!?)
    Regards,
    Steve
