Activity Forums Adobe After Effects Nucleo Pro 2 Question
  • Nucleo Pro 2 Question
    Posted by Gus Franklin on August 1, 2007 at 9:13 pm
    I have a Windows XP Pro system with an Intel E6400 and 4GB of PC6400 RAM. I also just installed Nucleo Pro 2.
    Previous to the NP2 install, I was using the /3GB switch to maximize my available RAM in AE CS3. Now that I have NP2, am I better served not using the /3GB switch so that my extra core can use more RAM as needed to background render, etc? Does it make a difference if I use the /3GB switch or not?
    I just want to maximize my new machine’s efficiency with the tools I have.
    Thanks.
    Steve Forde replied 19 years, 1 month ago 2 Members · 1 Reply
  • Steve Forde
    August 1, 2007 at 10:22 pm
    Honestly – I would disable the /3GB switch. Its a technology meant for a different Windows variant.
    The key is – you only have max of 4GB available to Win XP Pro – Period. Nucleo Pro 2 will eat up all 4GB, and the more distributed the better.
    From an NP2 perspective, dump the /3GB switch. Your renders and system will benefit.
    Steve
    GridIron Software Inc.
