ntsc/deck output problems
I am getting intermittent output to my deck via Firewire from PPro 2.
I have one project in particular that causes this problem. I can get no output to my deck within this project and once I load that project then switch to another, I get no output. Restarting PPro solves problem for other projects.I have the playback settings identical for the various projects. Restarting the deck has no effect. I’ve tried disabling services that may conflict to no avail. Saving a copy of the project doesn’t help.
I get “Can’t activate recorder. Try resetting camera.” in my capture window.
Any ideas how to fix?
Brian
Dual Xeon 3.2
2 G DDR
Seperate Drives for OS/programs and media
SB Audigy 2 ZS (use FW on this card)
JVC-DV3000
