Activity › Forums › Apple Final Cut Pro Legacy › NTSC Uprez to DVCPro72060p with piller box
  • NTSC Uprez to DVCPro72060p with piller box
    Posted by Tom Daigon on October 11, 2008 at 4:49 pm
    I need to convert ,in compressor ,video that is NTSC and uprez it to DVCPro72060p with piller boxes. I read Shanes great tutorial about converting using the full screen crop approach, but I want to have piller boxes for this project. Can anyone give me a step by step guide to achieving this? Thanks!
    Tom Daigon replied 17 years, 11 months ago 2 Members · 2 Replies
  • John Pale
    October 11, 2008 at 8:07 pm
    Drag your 4:3 NTSC movie into Compressor.
    Use the Preset (in Advanced Format Conversions) for DVCPROHD 720p60.
    In the Inspector, go to the Geometry tab and go to the bottom where it says “Output Image Inset (Padding)” select 4:3 – 1.33:1.
    Thats it.
    To preview the Pillarbox (to make sure you did this right…go to the upper right corner of the Preview window in Compressor and press the button in the upper right corner. Be sure to slide the split-screen slider above the preview window all the way to the left to see a preview of the entire encoded frame. You may have to toggle back and forth, as sometimes Compressor’s preview does not update right away. You should see your image pillarboxed. At least it works here.
  • Tom Daigon
    October 12, 2008 at 12:34 am
    Thanks John. Thats exactly what I needed to know. It worked like a charm.
