Activity Forums DVD Authoring NTSC to PAL using compressor?
  • NTSC to PAL using compressor?
    Posted by Chris Mason on August 11, 2010 at 8:45 pm
    Hi, I have an NTSC video (currently in MPEG2) that I need to convert to PAL. I rekon Compressor will work just fine for this, but just wanted to confirm my plan.
    Thanks, C.
    Michael Sacci replied 16 years, 1 month ago 2 Members · 3 Replies
  • Michael Sacci
    August 11, 2010 at 10:53 pm
    Do you have a PAL system to check the quality of the encode, I’m guessing not. If you do not you should never be converting standards yourself, how do you if you are good.
    But do a search here and you will find most people telling others there is normally no need to convert NTSC DVDs to PAL, most people in PAL countries can playback NTSC just fine.
  • Chris Mason
    August 12, 2010 at 4:39 pm
    Hi Michael,
    I took your advice and had the video encoded by a compression house. I just authored the DVD in DVD-SP and need to restrict it to Region 4. When I look at the Disc Info in Apple DVD Player, it still says it is a Region 0 DVD. Can you not specify Regions in DVD-R? Does it only work in replicated discs or should it work when burned?
    Thanks! C.
  • Michael Sacci
    August 12, 2010 at 6:28 pm
    Yeap, you have to replicate the disc if you want to use only certain regions. Then you have to format the title as a ddp file and burn that on to DVD-r this is not playable but it is what they would replicate from. (you can also put this folder on a thumb or hard drive)
