Activity › Forums › Adobe After Effects › NTSC to PAL resizing – Twixtor + Fieldskit
  • NTSC to PAL resizing – Twixtor + Fieldskit
    Posted by Anmol Mishra on April 26, 2008 at 10:55 am
    I read through the Re:vision Fx tutorial about NTSC to PAL conversion..Just one thing that was glossed over – it says
    “Apply any additional resizing/cropping as desired.”
    What is the best way to resize from 480P to 576P ? I doubt the AE internal techniques are sophisticated..Do I need to buy Instant HD or search for Algosuite, or DA Resizer ??
    Is there a specific method for resizing SD from NTSC to PAL that works better than others ? This would be applied to Progressive footage of course..
    Pierre Jasmin replied 18 years, 5 months ago 2 Members · 3 Replies
  • Pierre Jasmin
    April 27, 2008 at 10:34 pm
    Well in a nutshell I think you should resize individual fields:
    deinterlace -> resize -> retime
    or
    deinterlace -> retime -> resize
    Check this: https://revisionfx.com/support/faqs/generalfaqs/NTSC_to_PAL/
    and also:
    Also see: https://forums.creativecow.net/readpost/69/855271
    Pierre
  • Anmol Mishra
    April 28, 2008 at 2:14 am
    Hi Pierre! Would you consider a request for a tutorial that combines 60i to 24P conversion and also includes the denoise and deartifactor options ?
    I think your filters do all this – but its not really clear how its done..
    That would be really useful..I am leaning towards MB Suite 2007 mainly because of their tutorials – but Twixtor users swear that its better 24P than MBE.
    Obviously you will have a bias 🙂 but do you think the gap with MB Suite 2007 has reduced ? i.e. Does MB Suite uses a different deinterlacing algorithm now..?
    Cheers!
  • Pierre Jasmin
    April 28, 2008 at 2:30 am
    It’s something we are considering yes…
    Pierre
