NTSC to PAL question – Episode
I’m using Episode to convert the assets for an NTSC DVD to a PAL DVD, and these are undoubtedly newbit questions on conversion. The video is a movie, shot at 24fps). This PAL version is just to give to friend’s of the director overseas, so it doesn’t have to be perfect and the budget is LOW.
The original M2v and AC3 files were provided to me by a telecine house and done on a high end Sonic or similar system.
Now I need to convert these to PAL (I know, the workflow isn’t perfect, compression on top of compression, but again, this isn’t for distribution).
I used one of the presets in Epsiode to convert NTSC to PAL, and understand that it needs to be resized to 720×576 (16×9) and go to 25fps. This takes the 40 minute movie and makes it 32 minutes. Now, my idea is to “time stretch” the audio files in Soundtrack Pro to be the exact same length as the encoded video file from Episode. The time stretch features says that it doesn’t change the pitch, but of course, everything is sped up a bit.
Am I on the right track? Any advice appreciated.
