Activity Forums Apple Final Cut Pro Legacy NTSC to PAL problem
  • NTSC to PAL problem
    Posted by Meeroo Sareew on October 10, 2006 at 12:23 pm
    Hi. I got some NTSC footage on VHS and I need to make DVD from it and convert it to PAL. The problem is, I don’t know how to capture it. I tried to play it on VHS deck and record on my Sony HVR-M10E deck on mini DV tape but all I got is black video which I can’t capture. Could it be that deck cannot play NTSC? Since I’m in Europe, I don’t have any expirience with NTSC…
    Mac: Quad 2.5 + OS 10.4.6 + Final Cut Studio HD + Multibridge Extreme + Sony DVW-M2000P
    PC: Xeon 3.00GHz + Premiere Suite 1.5 + Avid Liquid + Decklink Extreme + Sony UVW-1800p + Sony HVR-M10E
    Jerry Hofmann replied 19 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 10, 2006 at 2:22 pm
    As far as I know, that deck won’t support a standards conversion so you need to have a conversion made for you or get a box (like an ADVC-100) that will allow you to capture the tape as NTSC, and then use compressor to convert it to PAL.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
