Activity Forums Apple Final Cut Pro Legacy NTSC to PAL mess (I think)
  • NTSC to PAL mess (I think)
    Posted by Nicolas 24 on August 3, 2005 at 9:41 am
    Hey guys,
    I’ve tried everything you suggested and it still doesn’t seem to work. I checked and there’s 30 frames per second on my canvas – so I might have been working on NTSC (?) thinking that I was on PAL (?).
    If I try playing out on PAL it freezes the first and last frame when I play and stop the timeline on the canvas. Whereas if I playout on NTSC it plays the images all pixelly and slower audio.
    What have I done?? More importantly, how do I sort this out? I should be playing out on PAL.
    Many thanks
    Nicolas 24 replied 21 years, 1 month ago 3 Members · 3 Replies
  • Rene Hazekamp
    August 3, 2005 at 11:22 am
    ha
    First try to figure out whether your footage is PAL or NTSC, if it is mostly NTSC, throw the PAL stuff away. Bring the NTSC stuff in
    a a ntsc timeline.NEVER MIX PAL and NTSC, it won’t work. edit your thing, if you’re lucky you can complete your project in NTSC.
    Make a self containing file and convert that one to PAL.
    For this you can use compressor 2 (though the default settings work poorly)
    rene hazekamp filmmaker
    https://www.renehazekamp.com
  • Uwe Klimmeck
    August 3, 2005 at 2:07 pm
    Or you purchase Graeme Nattress standard conversion filter.
    https://www.nattress.com/standardsConversion.htm
    Works fine for me from PAL-NTSC.
    Greetings
    Uwe
  • Nicolas 24
    August 4, 2005 at 11:41 am
    I know now what I did.
    Digitized PAL cause cam is PAL. FCP converted it to NTSC cause so was the setting and now cam being PAL and footage NTSC it wouldn’t play out properly.
    Can I convert my NTSC to PAL (so that I can play out to my cam?) or,
    Do I need and NTSC deck to play out to?
    Many thanks!
