Activity › Forums › Apple Final Cut Pro Legacy › NTSC to PAL is Choppy
  • NTSC to PAL is Choppy
    Posted by John Gramaglia on September 27, 2011 at 1:42 am
    Hi all, I have a 90 minute NTSC sequence that I need to make a PAL DVD of. I exported a quicktime from FCP brought it in to compressor and put the custom best 90 min dvd setting for pal on it, compressed it and brought the file in to DVD studio pro, but when I watch the clip in simulate, the picture is choppy on fast moving video scenes. I know this is because of the 29.97 to 25 fps conversion, but is there any other solution or work around?
    John Gramaglia replied 15 years ago 3 Members · 4 Replies
  • John Pale
    September 27, 2011 at 3:39 am
    [John Gramaglia] “Hi all, I have a 90 minute NTSC sequence that I need to make a PAL DVD of. I exported a quicktime from FCP brought it in to compressor and put the custom best 90 min dvd setting for pal on it, compressed it and brought the file in to DVD studio pro, “
    You can’t do it all in one step and and get a good conversion. The MPEG 2 encoder is not a standards converter.
    Do it in two steps. First do your standards conversion. Export your NTSC sequence and take that into Compressor. Convert it to PAL 8 Bit Uncompressed or PAL Pro Res 422. Open the Frame Controls, set the resize to Better (or Best) and the Rate Conversion to Better (or Best). Setting everything to Best takes forever and does not necessarily improve it much, so do a short test to see if Better does the job to your liking.
    Take your new PAL file. Compress that to MPEG2 using the same preset.
  • John Gramaglia
    September 27, 2011 at 2:33 pm
    Hi John,
    Thanks so much for your reply. It almost worked perfectly. The choppiness is gone but now the white titles over black at the opening of the piece are buzzing slightly. Is there a work around for that?
  • Sam Cole
    September 28, 2011 at 1:04 am
    [John Gramaglia] ” the white titles over black at the opening of the piece are buzzing slightly. Is there a work around for that?”
    That is a function of the frame blending. I always do a textless conversion and then re-add the titles. A pain in the A?!@%!!!
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
  • John Gramaglia
    October 1, 2011 at 4:11 pm
    Thanks so much for all your help. Yes, making the non titled version and then adding the titles after was a huge pain, but it all turned out perfectly.
    Thanks again,
    John
