Activity Forums Compression Techniques NTSC to PAL frame rate conversion
  • NTSC to PAL frame rate conversion
    Posted by Frank Raposo on February 22, 2008 at 4:03 pm
    I’m using Apple Compressor and want to change NTSC to PAL. My question is about rate conversion. After applying my settings, the frame size is changed but should I always go into the Frame Controls and change the rate conversion to “so source frames play at 25.00” instead of leaving the default “set duration to 100% of source? I’m thinking yes but I just want to make sure before I spend the time converting. Does this also apply to all other format conversions as well?
    quinnmcguee
    Frank Raposo replied 18 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
