Activity › Forums › AJA Video Systems › NTSC to PAL Converter
  • NTSC to PAL Converter
    Posted by Stuart Ferreyra on April 23, 2005 at 2:28 pm
    1.- Does anyone have an advice on a good standards converter?
    2.- Has anyone used the Nattress standard converter plug-in?
    I suppose a hardware converter is much better that a software plug-in,
    but I am open to both solutions.
    NTSC to PAL / PAL to NTSC
    Stuart C Ferreyra
    Timecode Multimedia
    President
    https://www.timecodemedia.com
    12340 Santa Monica Blvd.
    Suite 230
    Santa Monica, CA 90025
    310/826-9199
    Adolfo Rozenfeld replied 21 years, 5 months ago 3 Members · 4 Replies
  • Guy
    April 24, 2005 at 1:01 am
    The Nattress plugin works great- I would guess it looks better than less expensive hardware converters.
    Snell and Wilcox is supposed to have the best quality hardware converters (lots of $):
    https://www.snellwilcox.com/products/core/alcp.xml
  • Adolfo Rozenfeld
    April 24, 2005 at 7:27 am
    Compressor 2 will feature standards conversions using advanced optical flow technology.
    Of course nobody tried it yet.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
  • Stuart Ferreyra
    April 24, 2005 at 10:13 pm
    Yes, I know about Compressor 2.
    The problem is that the project has to be finished even before it comes out.
    I’ve been researching and the Kramer FC 4045 looks great, but I am not sure.
    Should I even risk it with the Nattress plug-in?
    After the NTSC to PAL conversion, I have to encode MPEG-2 audio & video for a PAL DVD.
    Any other thoughts?
    Thanks!!
    Stuart C Ferreyra
    Timecode Multimedia
    President
    Suite 230
    310/826-9199
  • Adolfo Rozenfeld
    April 24, 2005 at 10:47 pm
    Yes, Nattress’ G Converter is so far the best software tool available in terms of quality. There’s a free utlity called JES deinterlacer which also does it, with diverse results – sometimes excellent, sometimes quite poor. It’s by far the faster one. There’s a third option called Atlantis (by DVfilm) which costs more ore less like Nattress, is maybe simpler to use but gives not-so-good results. Nattress’ is the most versatile, it doesn’t just do PAL <> NTSC but it converts PAL/NTSC interlaced to PAL/NTSC progressive and vicerversa, and finally has a dedicated plug-in for NTSC/PAL to 24P (not sure if viceversa in this case, but very likely).
    G Converter’s quality IMHO is above that from “prosumer” hardware converters. In theory, Compressor 2’s *should* be the killer one, but until it ships it’s impossible to tell.
    Hope this helps.
    Adolfo Rozenfeld
