Activity › Forums › Adobe After Effects › NTSC to PAL Audio Sync Advice?
  • NTSC to PAL Audio Sync Advice?
    Posted by David Ornowski on November 21, 2006 at 11:53 pm
    I recently completed a series of NTSC DVD’s for a client who at the last minute requested delivery on DVD in the PAL format, too. I used the conversion method described in Cow FAQ, but had a heck of a time with the audio sync. I ended up using AVID’s AudioSuite Time Compression-Expansion plugin to change the duration of the audio track, which I then exported as a wav file, to replace the Encore generated wav file.
    While this ultimately did the trick, it required multiple rounds of experimentation to get the audio to match. I am looking for advice on a better workflow, as my client is likely to repeat this request. Are there better solutions for this than AE? Is there a way to calculate how much to modify the length of the audio track so I could get it on the first try? Any advice would be greatly appreciated.
    Oh, and advice on post conversion color correction would be helpful, too!
    David Ornowski replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
