  • Posted by Bart Winckers on October 27, 2008 at 4:54 pm
    Hello,
    i need to convert a 23,976 HD feature to 25 SD PAL. I am having problems with the frame rate.(I guess I am not the first…)
    First i used frame blending to keep the original length. This looks pretty ok but there are a lot of softer frames in there.
    Then i used motion estimation in compressor, which rendered very long, looked very good for predictable shots, but is horrible with faster moving scenes.
    Then I read on this forum to just change the frame rate interpretation, this would make the movie shorter, but I would not have the blended frames, i would have to pitch the audio though. Can you use this method for feature film?
    Which of these methods are used in the professional film world? Or is there another method?
    Thanx,
    B
    Rafael Amador replied 17 years, 10 months ago 4 Members · 3 Replies
