NTSC to PAL
Posted by Carlo Simone on January 23, 2006 at 8:12 pmCan I capture a finished NTSC.VOB file (Do not have the original M-PEG or .veg file) and simply drop it into Vegas and render to PAL without losing quality or sync??
Thanks..
Laszlo Kovacs replied 20 years, 7 months ago 6 Members · 9 Replies -
Gary Kleiner
January 23, 2006 at 8:51 pmYou will loose quality because you are using an Mpeg2 to generate another Mpeg2.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Ted Snow
January 23, 2006 at 10:42 pmGary, if a person has an NTSC VCR tape and wanted to send it to Germany to be viewed on a PAL system, can one capture the VCR tape into Vegas and render it as PAL? I figured since there are hardware and software packages for converting, then this probably isn’t possible within Vegas alone. Is this correct?
Ted Snow
January 23, 2006 at 10:44 pmBTW, this is an old home camcorder VCR tape…so no copyright infringments.
Gary Kleiner
January 23, 2006 at 11:17 pm[Ted Snow] “if a person has an NTSC VCR tape and wanted to send it to Germany to be viewed on a PAL system, can one capture the VCR tape into Vegas and render it as PAL?”
Yes, but you would need a PAL VCR to print to tape.
Gary Kleiner
Peter Wright
January 24, 2006 at 5:58 amThat would be much easier Ted, in fact if you mean a video DVD you may not even need to convert it, since most PAL DVD players will play NTSC.
If you mean sending data on a DVD, i.e. a PAL DV avi, then this is possible, but you’ll only get around 20 mins per disc.
Terje A. bergesen
January 24, 2006 at 4:06 pmIf you burn it to DVD, burn it as NTSC, PAL-land DVD players and TVs have no problem with NTSC disks in general. Typically PAL-land people wouldn’t buy a player-TV combo that wouldn’t play the DVDs they buy at amazon.com.
Terje A. Bergesen -
Laszlo Kovacs
January 24, 2006 at 4:51 pmHi,
[Ted Snow] “if a person has an NTSC VCR tape and wanted to send it to Germany to be viewed on a PAL system,”
Absolutely no need to do anything,
any 4 head (and some of the 2 head) VCR’s have
NTSC playback on PAL TV option.So, if you send that ntsc tape over, playing it will not be
a problem.By(t)e
Laca
