  • Posted by Kashish Arora on September 11, 2011 at 5:07 am
    It might be a basic issue, but i have come across this 2-3 times…and it creates a lot of trouble with the client.
    I get NTSC footage @ 29.97 fps shot on any digital camera like 5D, 7D etc. Now i am asked to give the output for both NTSC and PAL. So ideally what is the best way to do it, should i create a diff sequence with base frame rate 25 (which asks for a hell of rendering before i can even think of editing) or just edit the same and while exporting change the settings (which might result in out sync).
    please advice…kinda urgent..!!
    thanks
    Kashish Arora replied 15 years ago 4 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    September 11, 2011 at 9:44 am
    [Kashish Arora] “It might be a basic issue, but i have come across this 2-3 times…and it creates a lot of trouble with the client.
    please advice…kinda urgent..!! thanks”
    What about if you make an NTSC movie and hen you convert it to PAL (Compressor)?
    rafael
    http://www.nagavideo.com
  • Kashish Arora
    September 11, 2011 at 6:02 pm
    I have rally got no idea….i want advice and suggestions….how does this one works…and what are the pros n cons….u must be knowing as u use it…?
  • Rafael Amador
    September 11, 2011 at 6:34 pm
    Hi Kashira,
    This have been explained and discussed thousand of times in this forum.
    Type NTSC to PAL in the SEARCH window and you will find all the info you need and more.
    rafael
  • Kashish Arora
    September 12, 2011 at 11:09 am
    thanks a lot….will do so…
  • Andrew Rendell
    September 13, 2011 at 12:40 pm
    It’s worth getting hold of the technical requirements for a representative broadcaster who might take the programme. A couple of UK broadcasters are currently giving minimum specs of 50Mbps or better for origination and an approved motion predictive standards conversion for anything coming from a different frame rate than 25fps.
  • Laura Woodlondon
    September 22, 2011 at 9:05 am
    between NTSC & PAL, the main differences is the frame rate, NTSC with 29.97 fps, and PAL with 25. it’s very easy, using third party software with NTSC (*vob) and PAL (*vob) output, you can get the both formats
    Laura
    Laura Wood
  • Kashish Arora
    September 23, 2011 at 7:10 am
    thanks laura…
    but can u please tel me, which third party software are you suggesting here, which does not loses anything while encoding?
    thanks again
  • Laura Woodlondon
    September 27, 2011 at 5:11 am
    I’m sorry to let u know there’s no possiblity of no lossing any quality if re-encoding. Since the frame rate has neen changed from 29.97 to 25, the quality must be affected.
    And as for how to convert it. I googled and found a forum which mainly discussed about NTSC and PAL. hope it helps.
    https://www.google.com/support/forum/p/Google%20Mobile/thread?tid=57e429f4ce450e2b&hl=en
    Laura
    Laura Wood
  • Kashish Arora
    September 27, 2011 at 11:41 am
    Thank a lot Laura…really thanks…wil surely go thru d forum…!!
