Activity Forums Adobe After Effects NTSC square pixel 720×540 problem??? I’m a Brit!
  • NTSC square pixel 720×540 problem??? I’m a Brit!
    Posted by Jamesworsley on March 19, 2007 at 6:09 pm
    I know the issus of pixel aspect ratios etc. have been gone over a million times but i’m having a little problem. I’m from the UK and am used to Pal formats. However i have to create motion graphics for NTSC output (general NTSC 4:3) which will be combined (by someone else) in Final Cut Pro.
    In photoshop my document size is NTSC D1 720X540 square pixel.
    I’ve placed this into an NTSC D1 720×540 square pixel after effects comp animated everything and all is perfect.
    I’m then placing this comp into an NTSC D1 720×486 D1/DV(0.9) 4:3 comp to render out. It looks as though my original comp looks too big and overhangs the 720×486 comp?
    Am i missing something here?
    For PAL I’m used to creating sq pixel 768×576 work, placing into a 720×576 comp to render out.
    Any help would be appreciated greatly?
    James
    Sandy Chase replied 17 years, 3 months ago 6 Members · 9 Replies
  • 9 Replies
  • Robert Houghton
    March 19, 2007 at 6:16 pm
    Well for me that’s perfectly normal. We create our graphic plates in Photoshop at 720×540. When I set up for final output I make sure the end composition is 720×486 nonsquare pixel (.9 ratio). To make everything fit I just scale it down to 90% and hit the render button.
    The only time that can mess you up is when dealing with video footage that has not been deinterlaced (via footage properties on import). If you deinterlace the video you should be good.
    -Rob
    Motion Graphics Animation
    Professional & Freelance
    Respond2
    Opinions expressed above are not in any way connected to Respond2.
    Personal website under construction 😉
  • Jamesworsley
    March 19, 2007 at 6:25 pm
    ahhh i see.
    I’ve also just read that people design in 648×486 square pixel comp before they drop into a 720×486 non-square comp, is this the same as designing in 720×540 square pixel and dropping it by 10% like you said?
    Cheers
    James
  • Sam Moulton
    March 19, 2007 at 8:16 pm
    I’ve seen a test somewhere on the cow that showed two resolution charts, one scaled to 90% and one at 100%. One way you lost horizontal resolution, the other vertical. I’ve always worried about scan lines and how horrible they look when things are not right so I go for the 648 X 486 route most of the time for full screen artwork. I don’t like the horizontal edges to go soft. I really don’t think there’s much of a difference. I really don’t like scaling up D1 video to fit in 720 X 540 comps because of the scan line problems that can happen either.
    I found the thread. You can see the difference by dragging the movie control between 90 and 100%. I made my decision by looking at the lines of text as well as the charts. However, most of the time my graphics are moving around so there’s really no point to worrying about the 90 or 100% scale for graphics rule anyway.
    https://www.creativecow.net/forum/read_post.php?postid=107196265377204&forumid=50&archive=_2003
  • Steve Roberts
    March 19, 2007 at 8:31 pm
    If you look in the COW tutorials for “Pixel Madness” or “Dr. Strangepixel” by Rick Gerard, some things may be cleared up.
  • Jamesworsley
    March 19, 2007 at 10:51 pm
    Thanks for the help.
    So to confirm if i do all my design in 720×540 sq. pixel in Photoshop, i’ll be ok dropping the 720×540 sq pixel After Effects comp into a 720×486 rectangle pixel comp and scaling down to 90% to render.
    Just to let you know i’m only using photoshop layers, no video footage.
    Thanks again, it’s great to be able to get advice from people!
  • Sam Moulton
    March 20, 2007 at 5:50 pm
    I always use cmnd option shift H and not f… if there’s a mis match in scan lines or any other size, F will distort, h fits the layer to the width and preserves the pixel aspect ratio. I think it was Chris Meyer that gave me the idea. He said, at least I think it was him, that he never uses fit, only fit to width. You can get there from the the layer>transform window.
  • Darby Edelen
    March 21, 2007 at 11:08 pm
    As someone who works regularly with video and photoshop layers for final output on NTSC displays I have to ask: what is the benefit of working in square pixels at all?
    My entire workflow I use what I assumed was the ‘correct’ NTSC pixel aspect ratio of 0.9. In Photoshop my documents are always set to NTSC pixel aspect ratio… when I draw a circle in Photoshop and import it into After Effects everything is interpreted at 0.9 and nothing appears stretched (my circle is still a circle).
    What is the purpose of preparing documents in square pixels if they will never be viewed in square pixels? It’s not a rhetorical question really, I really want to know if I’ve been wrong all this time and should rethink my workflow =/
  • Darby Edelen
    March 25, 2007 at 6:49 am
    [wuzelwazel] “what is the benefit of working in square pixels at all?”
    I really wanted an answer to this… Nobody checking this thread anymore? (;
  • Sandy Chase
    May 29, 2009 at 7:21 pm
    Side-by-side comparison I do prefer working in 648X486 because as far as I understand, going from 720X540, the pixels have to be reinterpreted/mapped to 90% scale; in other words, generating new pixels from an approximation of the original. Going from 648X486, the pixels are stretched, but each pixel keeps its original color/position, so there is less artifacting. It’s subtle, but on text and fine lines it can make a difference.
    I do work in Photoshop with non-square pixels (especially helpful for HDV with its more extreme pixel stretching), but some programs, like Cheetah3D, I’m stuck in square pixels.
    I guess it would be ideal if every program could accommodate different pixel shape views. Occasionally I run into the reverse problem; for example, exporting production stills from Photoshop and 3D graphics, where I designed everything for non-square video, but they need square pixels to print.
