Activity Forums Adobe Encore DVD NTSC SD 4:3 to BD 16:9
  • NTSC SD 4:3 to BD 16:9
    Posted by Maria Cg on December 8, 2015 at 8:13 pm
    Hello,
    I need to convert NTSC videos from SD 4:3 to 16:9 for a Blu-ray project.
    I have AVI files 576×432 and resized them to 1440×1080, is this correct? Or shall I render my videos to 1920×1080? It causes a pillarbox effect anyway, and that’s fine.
    Also I’d like to believe the pixel aspect ratio and the frame rate doesn’t have to change.
    The files has square pixel aspect ratio and 29.97fps. Or should I change them to 23.976fps?
    Last but not least, I did some motions menus with AE. Does the render setting H.264 works well for BD? Or is it better to render a MOV and encode it with Compressor?
    Eric Pautsch replied 10 years, 9 months ago 3 Members · 4 Replies
  • Joe Barta iv
    December 9, 2015 at 2:37 pm
    Go with the 1920×1080 and the pillar box. That way you don’t lose any of your image or distort it by changing the ratio. Also, leave the frame rate at 29.97. You may cause some audio problems if the frame rate is not altered properly. Best to leave it alone.
    Someone else will have to comment on H.264 vs. .mov, I haven’t done any comparisons.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Eric Pautsch
    December 10, 2015 at 6:02 am
    This makes no sense. Your source is SD. Uprezzing will not improve quality but make it worse
  • Maria Cg
    December 10, 2015 at 10:12 pm
    Dear Eric, I know 🙁
    I have told my client a thousand times but they want to release Blu-ray.
    So I’m making magic here.
  • Eric Pautsch
    December 13, 2015 at 3:42 am
    Wow! That’s messed up on several levels.
    Good luck
