Activity Forums Apple Final Cut Pro Legacy NTSC problems
  • Posted by Charlie Key on April 12, 2010 at 3:56 pm
    Hey Guys,
    I have problem with a dvd from the states (I am in Uk). When I play with Dvd player app, it plays fine but when I open in Mpeg streamclip rip it plays terribly which I guess is the difference in frame rate. I believe it is from a NTSC pal file (in Streamclip it says native resolution is 720 x 480), I need to get it playing in an Xdcam ex timline on FCP.
    Any thoughts? Thanks in advance,
    Charlie.
    Rafael Amador replied 16 years, 5 months ago 2 Members · 3 Replies
  • Rafael Amador
    April 12, 2010 at 4:25 pm
    [Charlie Key] “it plays fine but when I open in Mpeg streamclip rip it plays terribly which I guess is the difference in frame rate. “
    If you rip a DVD you should be getting an standard file. Pal or NTSC, should play fine in MPGStreamclip.
    I’m a Pal lander too, so what I guess is that your MPEG-2 is p24 with pulldown.
    Little experience (thanks God) about this, but I suppose that you need to remove that pulldown.
    If I’m wrong any of our numerous NTSC pals will tell us.
    rafael
    http://www.nagavideo.com
    Pleas have a look to my clip:
    https://reels.creativecow.net/film/4452
    Feedback welcomed
  • Charlie Key
    April 12, 2010 at 4:40 pm
    “If you rip a DVD you should be getting an standard file. Pal or NTSC, should play fine in MPGStreamclip. “
    Thats what confused me, it plays OK in DVD Player app, but not in MPEG Streamclip. Otherwise, I would just chuck it in the bin!
    Do you think i should just rip at 29.97 fps to NTSC Pal?
  • Rafael Amador
    April 12, 2010 at 5:36 pm
    [Charlie Key] “hats what confused me, it plays OK in DVD Player app, but not in MPEG Streamclip. Otherwise, I would just chuck it in the bin! “
    I don’t know what to tell you.
    May be MPGStreamclip is more exigent. You know that many times things look well in QT, and in FC doesn’t look the same.
    I prefer to wait some expert to guide you. If I miss lead you, somebody will screem to me.
    BTW, had you had a look to the “Info stream” in MPGStreamclip?
    rafael
    Feedback welcomed
