Activity Forums Apple Final Cut Pro Legacy NTSC-PAL, FCP & Nattress
  • NTSC-PAL, FCP & Nattress
    Posted by Pierre-luc Pare on September 3, 2007 at 7:25 pm
    I usually have no problem with Nattress Standards Conversion but I have a question about the field order.
    Most of my clips are NTSC Uncompressed 8bit, that I need to convert to PAL Uncompressed 8bit. If I setup my timeline to PAL UFF and drag in my NTSC clip, FCP automatically add a Shift Fields -1, then I add the Nattress filter and choose LFF to UFF. Do both operations cancel the field change ? Should I leave the timeline to LFF and only use the filter to change it ?
    Uli Plank replied 18 years, 12 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    September 4, 2007 at 11:07 am
    Doesn’t FCP 6 simply do the conversion for you? i.e. I don’t think you’ll need to add Graeme’s filter on top of it.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Uli Plank
    September 4, 2007 at 3:31 pm
    Unfortunately, FCP 6 is still not that great when it comes to changing framerates.
    I’d stick with Nattress’ , just kill the field shifter and tell Graeme’s filter what field dominance your source has.
    Regards,
    Uli
    Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
  • Pierre-luc Pare
    September 4, 2007 at 6:17 pm
    That’s what I did.. and what Graeme suggested.
    When going to DVD, I read that’s not so important to keep UFF for PAL DVD, supposed you keep the same all the way through, is it right ? I never took a chance, but never tested.
  • Uli Plank
    September 5, 2007 at 7:09 am
    You only need to tell Compressor which field dominance your final product has, and every player out there should respect the flag it’ll insert.
    Regards,
    Uli
